跳转到主内容
Repair and maintenance guide for Bosch 11321EVS, a demolition drill made by Bosch, model number: 11321EVS.
2 个问题 查看全部
Seems to not be getting power
Green light on side of hammer goes on and off when I wiggle the cord. Cord has no visible damage and each wire in the cord has continuity. The wire connection block for the ground (green wire) seems to wiggle. The brushes on the motor appear to be only 1/2 worn.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
could still be an issue with the cable as you said the light blinks when you wiggle it. cut about 5 inches off the top and rewire it. i have repaired 2 titan sds breakers and the cable was the issue on both
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Ranford Johnson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 20
总计 180
