跳转到主内容
更大尺寸的 Nintendo DSi,北美市场于2010年3月开售。大多数维修只需要一个螺丝刀和塑料撬具即可完成。
Why is my dsi doesnt charging?
i tried to charged my dsi at first but the charging light doesnt turning on. but my dsi xl is showing it was charging, i thought it was just some error. but then after 2 hour, i noticed that the battery percentage is still at 50%, so i tried changing another place to charge but still not increasing. what do i do? should i change the ac adapter or change the battery or something?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
For posterity,
TL;DR - Component U11 is faulty.
I have a console with that exact problem. After fixing the female battery connector that was ripped off the motherboard board, I noticed both the positive and negative were shorted, which was very odd since it wasn't my solder job. Cross-checking with board schematics, I noticed that pins 9 & 10 on component U11 were shorting to GND on pin 4. Pin 9 & 10 were connected to the positive pad of the battery connector, so they shouldn't be shorting to ground like that. Replacing U11 from a donor board fixed the issue.
这个答案有帮助吗?
得分 0
1条评论:
To add: If that didn't worked, you can try to test with a new battery. But most likely it's just the U11 causing this.
完成的
添加一条评论
添加你的答案
raihan kavindra 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 112
