Why is my car not starting in the morning
I have a microbus 2.3 petrol, she cranks but won't idle ,this only happens in the moening ,during the day,she is fine
The year of manufacture would be helpful in diagnosing. However, what you describe is almost certainly a fuel delivery issue. From the symptoms I'm taking a guess your VW is using a carburetor rather than fuel injection. The carburetor probably needs a thorough cleaning, rebuild and adjustment.
Otherwise, look for large air leaks around gaskets or vacuum lines. Try spraying some carb cleaner around the carb gaskets and intake gaskets after starting and if you have a noticeable difference then this indicates a leaky gasket.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 65
