跳转到主内容
发布于2012年10月23日。酷睿i5或酷睿i7处理器。配备Apple Fusion Drive.
Hard drive caddy bodged
I'm new to the world of Mac's but I recently bought a cheap mac mini 2012 and updated the RAM and SSD for my daughter. I was so impressed with how cheap it all was (I even sourced a cinema display for it) that I decided to get one for myself.
All was great until I removed the caddy for the HDD and discovered that it didn't have the slots for the screws to mount the second drive. All the rest checks out as a late 2012 except for the drive caddy. I put the drive in and used some tape to keep it in place. Everything went back in, although a little tight and it all works fine. I am concerned that it will overheat as there may not be sufficient air flow to cool it.
Would I be better off finding a replacement caddy, although there are not that many out there, or will the bodge suffice?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
Though it isn’t ideal I would not worry about the tape especially if the Mac stays still. Airflow shouldn’t be an issue since it pulls airflow through the bottom.
这个答案有帮助吗?
得分 2
2条评论:
That's brilliant! Thank you and it sooths my worry about the house burning down 👍
完成的
Although it would help if I could spell "soothe"
完成的
添加一条评论
添加你的答案
joelhistory 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 11
总计 195
