跳转到主内容
加入维修社区 - 创建账户
2020年末13寸 MacBook Air 的维修指南、手册和故障排除帮助。获取自己维修 2020年末13寸 MacBook Air 所需的一切。
Key switch won't stay attached to hook
Hey!
The bottom left attachment of the white plastic scissor mechanism of my command key won't stay properly attached to the metal hooks. They key works, but touching the upper right portion of the key makes the bottom left stick out above the other keys.
I've tried applying some soft pressure to the metal hooks to see if I can bend them into a place that will hold the plastic mechanism, but to no avail.
Reference image below: the plastic mechanism is able to slide out from underneath the bottom left attachment hook.
Edit:
Below some more pictures
Key pops out
Scissor mechanism as attached
Scissor mechanism comes undone on bottom left with pressure on top right
Removed the mechanism
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
These mechanism are so fussy about how they go back in again. What would help the most is if we could see what you’re actually looking at. I would want to see all the bits: the back side of the keycap, the scissor, and the actual mounting point on your Mac’s keyboard.
As much as I think it’s wasteful, there’s a solid reason why Apple mandates that anytime a keycap is removed during the course of service, it is replaced with a new one. Because it removes the factor of the old key cap. And they are so easily damaged once they’re loose. Or put back in improperly.
My money is on something bent on the keycap itself, but that’s just my wild conjecture.
这个答案有帮助吗?
得分 4
1条评论:
I've edited the question with some aditional pictures. The keycap itself seems to firmly attach to the scissor mechanism
完成的
添加一条评论
添加你的答案
leadstripes 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 22
总计 386
