跳转到主内容
The Dell Precision T1700 is an entry-level workstation that offers true workstation performance in two compact sizes for about the price of a desktop PC.
My Dell precision t1700 Bios been corrupted
my Dell precision t1700 Bios been corrupted and is unreadable(failure to POST) i tried to load a O.S with a flash drive and while switching to uefi safe move and restarting my computer no longer post.
clearing cmos ,drain of power ,checking all ports monitors and cords dident fix the issue Computer was maybe interrupted during load(Cant remember but most likely).any help to fix my BIOS.
i Might need a Flash.Anyone with experience with this??
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Here is a direct download link for your BIOS from Dell themselves! When you download the file it may say something like "T1700A28" so just rename the file to BIOS_IMG.rcv changing the filename and file extension.
If you cannot see the file extension, then go to the Windows Start icon and type in Folder Options.
  1. Click View and clear the HIDE EXTENSIONS FOR KNOWN FILE TYPES and click OK.
  2. Right-click the file saved on the desktop, the extension for the file .exe can now be seen and changed.
Now once you got your .rcv file made, find a formatted USB drive, put the file on there and plug it in to your computer. now on the computer, press the F2 key several times at the Dell logo screen during startup. Or, press the F12 key several times at the Dell logo screen during startup, and select BIOS Setup or System Setup from the menu.
这个答案有帮助吗?
得分 0
2条评论:
it is still unresponsive. Keys don't work
完成的
@gannibalgaming Are you able to use a different keyboard or switch where you plug in the keyboard at?
完成的
添加一条评论
添加你的答案
Gannibal Gaming 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 34
总计 738
