跳转到主内容
Whirlpool WTW4816FW or the Maytag Centennial washer MVWC415EW2.
15 个问题 查看全部
Please help it fills then drains
Ok so yesterday my whirlpool washer worked fine today I noticed evertime I went down it would be on the wash stage not doing anything. So I started another cycle, it will fill and as soon as it's done it drains all the water,and seems to get stuck on drain mode for a min then the wash light pips on and it never does anything? Please help I'm totally stumped on this one.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Hi @matthewmcc79269
Is it only the wash LED that comes on (is it blinking or is it steady?) or is there another LED on as well?
Here's the tech sheet for the washer.
Go to p.2 to see how to run the diagnostic tests - see Activating the service diagnostic test mode.
Once you have run the tests, decipher the error code as shown on p.3 - see Fault/Error Code Display Method
The error codes and their possible causes are shown from p.6 onwards.
Bit strange if there is only the wash LED blinking as there is no code pertaining to just the one LED except if it's a blinking fill/sensing LED and then it's an F0 E0 code - no fault
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Matthew Mccartney 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 14
总计 86
