跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
问题已关闭
Unable to obtain Verizon 3G signal
I have a Verizon iPhone 4s that cannot receive a 3G signal. I do see the bars, the Verizon wording, and roaming "O" symbol. I am pretty confident the area I live is has a good signal.
Problem occurred after I replaced the digitizer. I made sure everything was connected and in place prior to powering it up.
I verified the pressure contact was cleaned prior to installing it. I also swapped out a pressure contact from a functional iPhone. Still wasn't able to pick up a 3G signal.
Can anyone advise on next steps to troubleshoot? E.g. Reset all settings perhaps? Upgrade iOs?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
You might want to try this:
1. Save everything on your phone not through a backup (Write a list of apps, sync notes, contacts, etc. through iCould and save photos/videos on your computer)
2. Restore with the latest software
3. Put everything on the iPhone, not from a backup (download apps, setup iCloud, and put the photos/videos on the phone.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 838
