跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2397 个问题 查看全部
问题已关闭
iPhone 4 screen display problem! Help needed!
I Broke my iPhone's front screen and the touch screen would not work... i repaired the screen with a new Digitizer/LCD screen replacement. After i finished putting the iPhone back together i powered it. The front screen came on but you could only see white light and not make out what was on the screen. I even got a call while it was like this i was somehow able to answer it by sliding my finger across the bottom of the touch screen how you would normally answer a call. so this mean the touch works but the display doesn't?
Does anyone have any suggestions to what might be the problem.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
How did you break it?Are you sure you ordered the right screen because there are different screens for the verizon and the at&t versions.Last try a hard rest if that does not work you could have gotten a faulty display.Other than that it would be a board issue
这个答案有帮助吗?
得分 0
添加一条评论
yes my Iphone only display problem but all thing write, camera and phone call all work but only display problem
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 1,719
