跳转到主内容
Model A1990 / EMC 3359. Released in May 2019 with new 6-core and 8-core processor options.
88 个问题 查看全部
Touch ID security in flat or switch?
broke the touch id flat replacing topcase…
Is the security in the button or on the flat cable?
i am thinkin of buying a new touch id cut it and solder the button to my old flat will this work?
I dnt want to change my logic case and i like to use the fingerprint 😅
So is t2 security thing in flat or in button itself?
Thxx ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
The sensor is the top black plate, the power button is the blister switch below. Sadly, without the original sensor your system won’t work properly. This will require a new logic board and the mated sensor.
TouchID sensor
The power switch
这个答案有帮助吗?
得分 1
3条评论:
I cant remove the sensor from my old switch?
完成的
is the t2 security thing on the red or the yellow part ?
to see if i can soldier the button
完成的
@gjvjojvnsj4nn12 - Apple designed the part so it can’t be altered as that effects the security of the TouchID and the invalidates the T2 encryption so the system is the workable.
The first image is the TouchID sensor marked in red. The second image is the power switch again marked in red.
完成的
添加一条评论
添加你的答案
george.kassab 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 65
