跳转到主内容
A1706/EMC 3071—于2017年6月上市,这台13''MacBook Pro以可升级至3.5Ghz酷睿i7动态超频至4.0GHz的Kaby Lake处理器为特征。
Is keyboard backlight on keyboard or shield
Hi,
I am trying to repair a A1706 Macbook, that has no backlight on several keys. Im not seeing much info on this online, is the keyboard backlight located on the actual keyboard bottom? or the film behind it?
I see the "keyboard backlight" film being sold online, Im not understanding how it gets power also? as there is no power ribbon as previous models ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
The keyboard is a sandwich, behind the keyboard is the backlight plate and then a black cover sheet.
This is one example US Keyboard Backlight For MacBook Pro 13" Retina A1706 2016 2017 (Touch Bar) there are a few versions depending on the language layout.
It’s a bit of a chore to get to as you need to strip the system down quite far. We don’t have a guide on the process, but this MacBook Pro 13" Touch Bar 2017 拆解 will give you an idea what’s involved as the backlight is under the logic board.
这个答案有帮助吗?
得分 0
2条评论:
Thanks for your response dan. I have no problem digging in to this machine.
I took out the underlay underneath the keyboard from another palmrest assembly, which is not the same as previous versions where you could actually see the led's and ribbon cable. It has no ribbon cable or source of power (?)
Which makes me think the led's are actually embedded in the keyboard or on the film
完成的
@broumi - The keyboard is under the logic board not the palm rest which is where the battery is.
The backlight is quite thin so you might not realize it.
完成的
添加一条评论
添加你的答案
Bob R 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 119
