跳转到主内容
加入维修社区 - 创建账户
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
Is Replacement Battery defect?
Replaced the battery coming with the iPhone by a new Battery received from ifixit following the the ifixit-guide.
When connecting to the charger the battery appeared on the screen showing a small red bar and a symbol similar to a lightning, but the battery won't charge.
I once more disassembeled and reassembled the IPhone checking all connectors, but no better result. No real function on Power- and Home-button.
Any suggestion what to do next?
Gerald Abendroth
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Double check that you ordered the correct battery (a 3GS battery wont work with a 3G) and see if your old battery will charge up (eliminating dock and logic board issues). If you've got the right battery and the old battery seems to work fine you may have received a defective battery. Contact our sales department and they'll get you straightened out!
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
geraldabendroth 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 361
