跳转到主内容
Repair guides and support for Nextbook tablets.
not able to connect to a network
not able to connect to internet or wifi both are working on my other devices Nextbook model NXWIOQC332G Windows 8 THANKS
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
  • Select the Start  button, start typing cmd, right-click Command Prompt in the list, select Run as Administrator, and then select Yes.
  • At the command prompt, run the following commands in the listed order and then check to see if that fixes your connection problem:
    • Type netsh winsock reset and press Enter.
    • Type netsh int ip reset and press Enter.
    • Type ipconfig /release and press Enter.
    • Type ipconfig /renew and press Enter.
    • Type ipconfig /flushdns and press Enter.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
oralia castelo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 117
