跳转到主内容
加入维修社区 - 创建账户
型号 A1213或A1218,闪存容量:8、16及32GB
iPod won't hold a charge even AFTER replacing battery
After 2 years, my iPod stopped holding a charge. I would plug it in and after a couple seconds i would get the red battery icon saying the battery was low,but with the plug over it indicating that charging was complete. Sometimes it would show it was charging and the indicator would go green, so I would leave it. But when I came back to it the battery had drained instead. I just replaced the battery on it figuring that it was the culprit and was ecstatic when it charged right up, but after I synched it it was back to it's old shenanigans. Any ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
最有帮助的答案
The batteries in most iPods have a ground strap that grounds the battery to the iPod's case. If you don't install this or do it incorrectly, the battery will not retain a charge
这个答案有帮助吗?
得分 1
2条评论:
Did you mean "will *not* retain a charge"?
完成的
yes, sorry
完成的
添加一条评论
I don't know about a ground strap. It had a ground wire that soldered into te board along with the pos and neg. I figured the connector might be the problem.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
hennemonger 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 3,476
