跳转到主内容
加入维修社区 - 创建账户
A1706/EMC 3071—于2017年6月上市,这台13''MacBook Pro以可升级至3.5Ghz酷睿i7动态超频至4.0GHz的Kaby Lake处理器为特征。
white touch bar problem
Hi can you help me cut corners cost wise I aim to do the repair my self but want advice please.
so my Mac Book Pro has a touch bar issue the display on the bar is now permanently white but after a short period it used to fliker with sqaures.
the touch bar functions are still working so does the fingerprint id too.
but the display is white is there a way to fix this with out replacing the hole touch touch bar Bar please
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
So the question is… Is the TouchBar or the cable between the logic board and the TouchBar the issue?
You could try replacing the cable MacBook Pro 13" Retina (Late 2016-2019) Touch Bar Display Cable it’s a fair amount of work. Otherwise the TouchBar OLED panel it’s self is bad MacBook Pro 13" Retina (Late 2016-2017) Touch Bar Assembly which is much harder to replace.
Replace the cable that connects the display portion of the touch bar to the logic board.图片
产品
$9.99
Replace a damaged or malfunctioning touch bar assembly compatible with a Late 2016 or 2017 13" MacBook Pro with Retina display.图片
产品
$54.99
这个答案有帮助吗?
得分 0
3条评论:
Hi many thanks for getting back to me. So I suppose it's a process of elimination thing. ill get a new cable first fingers crossed its only the cable.
完成的
Any luck fixing this issue?
完成的
@shermyg - I'm sure bseth got things working, likely just needed a new cable and the driver logic within it likely failed.
完成的
添加一条评论
添加你的答案
bseth1975 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 19
总计 743
