跳转到主内容
加入维修社区 - 创建账户
一款任天堂为 Switch 系统生产的无线、传统的视频游戏手柄。型号:HAC-013。
Left stick double clicks and gets stuck
My pro controller (2017) has a problem with its left stick that seems to double click when pressed down to the right. The right stick doesn’t do this. After opening it up, I noticed that the left stick has a loose part in the module that the right one doesn’t.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Thank you for this, I realised I had the same issue, glue didn’t hold so I use a small thin elastic band and wrapped it around the area to hold the loose part in place and now it no longer sticks:)
这个答案有帮助吗?
得分 1
添加一条评论
Eventually it's gonna fall off, but luckily it hasn't yet so gluing it into back into place should be easier. Use a small amount of a strong glue to put it back in position, if you don't want to replace the whole joystick. You can use your working joystick as a reference for where exactly it should be.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Juexis 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 49
总计 1,131
