iPhone 11 does not charge. 0 Amps. Charging ic, or special charger?
i just changed the charging port/flex of an iphone 11. the phone was sealed. i dont have an original charger and have only an old cable. the cable is propably from the first iphone model which used this charging port.
so my questions are:
do i need a better cable or a special charger which can deliver at least x amps, so the iphone starts charging??
or is the charging ic, or the new charging flex cable faulty?
does the ic or the port goes bad more often on an iphone 11?
if the ic is bad, can you often messure a short etc?
best regards
does the phone turn on
由 daniel 完成的
