跳转到主内容
M1 Mac mini 是Apple的首部使用自研單晶片系統(SoC)的機型之一,整合了中央處理器(CPU)、圖形處理器(GPU)、記憶體(RAM)等等主要元件,以提升能耗比。此代Mac mini 的M1芯片CPU擁有8個核心,其中有4顆是效能核心(P-Core),而另外4顆為效率核心(E-Core),並帶有8核心的GPU。
I need help with my Mac Mini
Well my Mac Mini was slow. So I formated it. When I was creating a login for the computer, the energy fell, I was like “oh okay then I will wait it to return” then after it returned it was like if I already set it up. I said “oh okay I’ll just put the password that I chosen” it did not work. Then I tried to reset it from my iCloud but It did not work it seems that it’s not in my iCloud but it’s appearing there, so I’m stuck with a Mac Mini that has a password witch is not the one that I have chosen and my iCloud can’t reset the password. If anyone can help before I bring it to an thecnical assistance I’ll be grateful
Thanks!
Atualizar (04/16/23)
I finally got it unlocked but now I have another problem.
It’s in Portuguese because I’m from Brazil. So it’s now saying “the version of macOS in the disk selected needs to be reinstalled, Use the recuperation tool to reinstall macOS or select another disk to initializate”
Then there is two buttons the first one “recuperation” and the other one “disk initiation”
Atualizar (04/17/23)
Thank you guys so much for help, today I’ll bring the Mac Mini to an Apple Store to see if they can fix it, again thank you so much for the help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Ouch! Did you buy this system new or used?
Dig out your paperwork as you may need it
这个答案有帮助吗?
得分 1
5条评论:
It’s new, it’s actually my old Mac Mini now I have the M2 Mac Mini
完成的
Sure I’ll find it somewhere
完成的
@eugenioaragao - Hopefully you can get to an Apple Store and it’s still covered under warranty. Some countries have Two years others only one.
完成的
I just turned it off and on again and that happened
完成的
@eugenioaragao - Your system shouldn’t need reformatting or need a fresh macOS. Something is off here.
完成的
添加一条评论
The picture you added in your update indicates it doesn't recognize an attached keyboard and/or mouse. You may need to connect them with a USB cable for the mac to recognize them the first time. But it seems like you're making progress.
这个答案有帮助吗?
得分 1
1条评论:
I hope I get it running again I’m pretty worried as it’s an expensive computer, my son said if I don’t get it running he will bring it to the Apple Store tomorrow to see if they can fix it up.
完成的
添加一条评论
添加你的答案
Eugênio Aragão 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 15
总计 282
