跳转到主内容
加入维修社区 - 创建账户
The second generation 11" iPad Pro was released in March 2020 with the model numbers A2228, A2068, A2230, and A2231.
Will iPad work WITHOUT LIDAR cable
I just replaced the display (screen and digitizer) but there is nothing showing. Could this be a bad LIDAR cable? If so, can I remove the cable completely. Any other suggestions are greatly appreciated
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I followed the ifixit guide. I plug the iPad into my computer and can view the iPad on my File Manager but cannot see the screen display
完成的
添加一条评论
1个答案
最有帮助的答案
I don't believe a bad LIDAR cable would be responsible for a "no image" condition like you're experiencing. I would double check your connections and make sure they're secure. Inspect the connectors for foreign objects and debris and make sure they're not damaged. Depending on where you got the replacement part from, it's a possibility you may have received a defective part. If your old screen still works, you could reconnect that to your device to narrow out the possibility of a defective part.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
juricta 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 12
总计 184
