跳转到主内容
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
549 个问题 查看全部
I need to control the fan after HD swap TIGER 10.4
I know many apps such as macfanscontrol and smcfan control etc.
Nothing is compatible with Tiger ,which cannot be changed on this elderly senior citizen of a mac
The fan is running full pelt ,because the thermostat is no longer connected
Please I need a solution before giving it back to my customer
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Did you follow this guide iMac Intel 20吋“EMC 2133和2210 硬盘更换? You needed to recover the drives sensor to put it back in. I hope you still have it otherwise you’ll need to get a replacement. Here’s one source TheBookYard - iMac Alu 20" Temp Sensor, Apple P/N 922-8196
这个答案有帮助吗?
得分 0
2条评论:
I found a copy of SMC fan control that is compatible with OS Tiger
So thanks for your reply
The drive I installed isn't compatible with a thermostat , otherwise I would have put it back in.
Regards
Martin
完成的
@martinclem - ??
The sensor plugs into the logic board. The sensor is just stuck onto the drive. You do realize your systems SMC logic is still in CPU Safe Mode as the sensor signal is missing. Yes, you can alter the fans RPM but that doesn’t solve the root issue and besides as SMC is not controlling the fans RPM your cooking your system!
One more shoe to fall here! This series SATA interface can only support SATA II (3.0Gb/s) most drives today run at SATA III (6.0Gb/s). Make sure the drive is compatible if it doesn’t list SATA II (3.0Gb/s) you’ll need another drive.
完成的
添加一条评论
添加你的答案
Martin Clem 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 22
