跳转到主内容
2.3L 4cyl or 3.0L V6, 6th Generation
431 个问题 查看全部
Cranks but won't start
2000 Honda Accord 2.3 cranks but won't start. I have replaced all the common issues ignition switch, ignition coil, etc. It is getting fuel has compression but the spark seems very weak. Tested the voltage to the coil and it is 3.3 volts. Any suggestions on where to go next?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
The voltage from the coil seems low. Not much experience with Hondas though. Is that the output voltage or what's coming into it?
这个答案有帮助吗?
得分 0
1条评论:
That is voltage to the coil
完成的
添加一条评论
if you haven't done this yet, check your eng, fuse. my car would crank but not start & that was it. it's a 10amp
just now by will
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Michael Leonard 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 36
总计 291
