跳转到主内容
A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
Blackscreen with blue dots when booting - RESOLVED
So this morning i turned my pc and worked perfectly but then my pc got so loud for some reason my screen turned black and then i turned my pc off by pressing the boot button on my pc after this i get a Blackscreen with blue dots.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
7条评论
I did happen before but worked fine once i restarted
完成的
Secure bios was off if that helps
完成的
Hi @redmoka65383,
What is the make and model number of the motherboard and GPU card?
Can you try another monitor (TV perhaps if GPU has HDMI output) and check if the same problem occurs?
完成的
Motherboard- Nzxt N7 B550 amd
CPU - Ryzen 7 3800x
I will try on my tv and i do not know the model numbers
完成的
Bios work perfectly
完成的
显示更多的2条评论
添加一条评论
2个答案
已选择的解决方案
Fix FOUND TURN ON SECURE BOOT
这个答案有帮助吗?
得分 1
4条评论:
and how do i do this exactly?
完成的
nvm its in the bios
完成的
I found a solution, Take all of your Pc cables off, start your pc without cables, then wait 10 seconds and press the start button for 10 seconds till it takes all the extra energy out, plug in all of your cables back and turn your pc on.
完成的
Thanks Zett had this problem as well and this worked for me not sure why it worked but it did!
完成的
添加一条评论
最有帮助的答案
Hi @redmoka65383
Here's the user manual for the motherboard.
Turn on the PC and check if any of the POST Leds are on. They will tell you if there's a CPU, Memory, GPU or HDD/SSD problem. See p.38 of the manual for their location on the motherboard.
It may be that the motherboard is not passing POST (power on self test) on startup.
这个答案有帮助吗?
得分 1
1条评论:
@redmoka65383
Question to ask is why was it turned off if you didn't do it. was there an update or something?
完成的
添加一条评论
添加你的答案
RedMoka 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 28
总计 4,399
