跳转到主内容
A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
20 个问题 查看全部
CPU Temps are low but FANS are at max speed
I had a prebuilt pc that overtime I had to replace parts and now the cpu fan is the only thing left of the original.
The current specs are
MOBO: GIGABYTE GA-B75M-D3H
CPU: i5-2500K
RAM : 32gb (8gb 1333mhz x 4)
Storage: SSD 254gb
OS: Windows 10
Windows and bios are up to date. The thermal paste is freshly applied. The fans are set to silent in the bios. CPU temps is around 35c. But the fan is running at 4272RPM all the time
I need to know the pc is fine and its not going to explode or something. Is there anything I can do right now? Should I replace the cpu fan? Is the motherboard i bought defective? Is here a way to manuall set the cpu fan speed?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Hi @kdme_
It may be a problem with the temp sensor in the fan itself.
Have you checked that the fan heat sink fins are clear and dust free?
If they are then perhaps changing the fan may be the best option. If the new fan still runs at high speed then you know that it is not the fan
这个答案有帮助吗?
得分 2
2条评论:
MIght be but now I think its the motherboard as the next day after I posted it did not turn on.
so i turned everything off and reseated the cpu and ram. I turned it on again and it freaking grounds me.
Any thoughs on this?
Honestly I'm thinking of just biting the bullet and just built a new pc with new parts
完成的
@kdme_
What do you mean by "....grounds me."?
Did you get an electric shock?
If so something it shorting out to the chassis (if that's what you wer touching at the time. Check the motherboard standoff screws are all in in case the underside of the board is touching the case.
Reinserting the CPU and the ram may have pushed the board down until it touched.
Also check for any cables rubbing against the chassis etc.
完成的
添加一条评论
添加你的答案
Kyle 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 5
总计 738
