跳转到主内容
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
20 个问题 查看全部
Adapter + Western Digital Green 240 GB
I used an adapter of SSD for the Macbook Pro Retina 2012 A1398 and A1425 that bought from AliExpress plus the SSD of Western Digital Green 240 GB M.2 (2280) SATA 3 (6.0 Gb/s) but the macbook can't detect it????
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Apple did their own thing! And in doing it created a lot of confusion. So let’s start up with a useful diagram
Here we can see three paths. The right most are M.2 the left is Legacy SATA. Which is what this system uses. Refer to this great guide! The Ultimate Guide to Apple’s Proprietary SSDs jump down to Generation Two for the full lowdown.
这个答案有帮助吗?
得分 2
添加一条评论
Hello! You'll have to upgrade to macOS Big Sur (11.7.4) or later for your laptop to install the EFI update needed for these adapters to work. Do you still have the original drive for this computer? If so, that'd be a relatively easy fix.
这个答案有帮助吗?
得分 0
3条评论:
As long as I know, this macbook can only upgrade to the Catalina macOS
完成的
@armin1 Apologies! I meant catalina, forgot that that was the latest ver for these machines
完成的
@ezzgen - This is not a NVMe Drive'd system as such it doesn’t need an updated OS or firmware.
But it’s not a AHCI drive based system either! It’s an mSATA Drive’d system. Which is why this M.2 SSD won’t work.
完成的
添加一条评论
添加你的答案
Armin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 98
