跳转到主内容
The Nintendo 2DS is a handheld gaming device developed as an entry level version of the Nintendo 3DS with nearly identical hardware, but without the 3D upper screen function.
192 个问题 查看全部
ejects game cards as soon as they are put in
i think the bar that is holding the games down is bent, and the screen has a very deep scratch in the top right corner, it can read games, as seen in the video, but the bent bar will push them out
anyone have a idea of how to fix this?
@flannelist Hm, I noticed that the spring will go in halfway, but then will push it back out
so the bar it the issue,because it wont go into the locked position with out force?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
最有帮助的答案
This the part of my morning where I’m scraping through all the tear downs of 3DS style devices to see if there’s an X-Ray of the cartridge reader in any of them just for sake of clarity. But no dice.
I have not specifically worked on one of these, so you can take what I say with a grain of salt, but after having a look at the outsides and using my morning hyper-focus, my inkling is that this is likely a product of two mechanisms. One to keep the spring from ejecting the cartridge and one to keep the cartridge from falling out. I suspect they may actually be the same part within the cartridge reader, but separate things. I suspect your issue is with the former. That’s the thing that gives the satisfying click when you’ve inserted the cartridge far enough to engage the spring lock.
Update: Realized I never finished my thought. It might be difficult to fix if it is the “Click” that’s not engaging. Because the bits that actually handle this will be inside the cartridge reader, and unlikely to be accessible. I might see if I have something similar I can rip apart just to see. I have DSi XL and a DS lite in my apartment somewhere I can compare.
Stay tuned.
这个答案有帮助吗?
得分 1
6条评论:
Btw, it's a 2013 basically just a 2013 3ds lite, just in case there's a upgraded card reader or something like that
also the it started when a game card was put in backwards by a younger sibling :(
完成的
@flannelist holy crap
mk so I opened it,
the springs for the trigger buttons are corrded
Andi cant get the top cover covering the game card reader
完成的
@flannelist Is there a way to take off the sliver casing on the game reader?
完成的
@flannelist
could i possibly try to bend the bar in a certain way, would it start to function normally again?
完成的
@flannelist, so i got it to fully eject cards, and to click, but it still will push them out as soon as they are put in
完成的
显示更多的1条评论
添加一条评论
添加你的答案
timtom7777 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 11
总计 97
