跳转到主内容
加入维修社区 - 创建账户
在与惠普合并前,康柏电脑制造全系列的笔记本电脑。 现在他们由惠普制造,拥有最基础功能的电脑。
Compaq Splash Screen to a Black Screen
I have an old Compaq Armada m700 Laptop. When I turn it on I see the Compaq logo and then the Screen goes black the laptop does boot into Windows and I can hear the Windows welcome sound. Also if I hook up a second monitor it displays windows find on the second Monitor. I want the Laptop's main screen to work. If I try and get into the BIOS via F10 the screen stays black. If I connect the 2nd display it will show the BIOS screen. I originally thought it was a hardware issue but I do see the Compaq Logo Splash screen.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Hi @krispurchase,
Try starting the laptop in safe mode and check if the laptop display works OK.
You don't say what OS is installed so if not Win10/11 search online for "(insert Win OS # e.g. Win XP, Win 7 Win 8 etc) safe mode" to find out how to do it
完成的
@jayeff Thank you for the reply. It is an older laptop running Windows XP. I have tried starting in safe mode. When I start XP in safe mode the Laptop's display still is not coming on. I had to connect a second monitor to see Windows XP in safe mode.
完成的
添加一条评论
1个答案
已选择的解决方案
@krispurchase
With the laptop on etc try shining a flashlight at an angle close to the laptop screen and check if you can detect any images.
They will be very faint if there so trying this in a darkened room may help to see them
If you can see images then there's a backlight problem with the display.
Either a faulty backlight power circuit on the motherboard, a faulty LVDS cable/cable connection between the motherboard and the display or a faulty display.
I realize that you said that the logo splash screen is being shown so what I said above doesn't make much sense as you would think that the backlights are OK but if you can see images then something is causing the backlights to turn off - lid switch perhaps idk.
What is the motherboard's board number? Knowing this may help to find the schematic as I think that they may be needed.
Update (04/12/23)
@krispurchase
You mentioned that you can get into BIOS using the external monitor as the display is this correct?
This is very strange as normally BIOS is not available to external displays. External displays only become available to be used after Windows is loaded and then you can't get back into BIOS
Looking through the maintenance and service guide it shows that there's an option in BIOS to make the laptop display as a "secondary" display and an external monitor presumably as the primary. Maybe that's why it shows the logo on startup but then you see nothing after that because it's switched the output away from the laptop display.
Perhaps the BIOS has become corrupted.
Maybe try a power refresh and check if that restores the BIOS back to factory defaults.
  • Turn off the laptop if on and then disconnect the charger if connected.
  • Remove the main battery from the laptop.
  • Disconnect the RTC coin cell battery from the motherboard. When the RTC battery is out measure its voltage. If it is <2.5V DC replace it. Search online for CR2016-WR to find suppliers that suit you best.
  • Press and hold the laptop's Power button for a full 30 seconds and then release it.
  • Reconnect the RTC battery (or its replacement), reassemble the laptop, reinstall the main battery, reconnect the charger and check if the laptop turns on with its display OK.
If it does there may be a message about the date and time being incorrect. This is normal as the BIOS has been reset. When the D&T have been corrected the message won't appear the next time that the laptop is started.
这个答案有帮助吗?
得分 1
1条评论:
Thank you @jayeff How / where can I find the motherboard's board number? I have tried to see if there is an image with a flashlight and do not see any image. I did notice if I hit the Fn+F4 the screen does Flash a few white lines.
完成的
添加一条评论
添加你的答案
Kris Purchase 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 44
总计 343
