跳转到主内容
High performance tablet computer released by Apple on November 11, 2015. Model A1584.
131 个问题 查看全部
I have black screen on my iPad but touch works
The touch functionality of the 1st generation 12.9-inch iPad Pro appears to be functioning properly, but there is a lack of illumination on the screen, resulting in a completely dark display. Is there any indication of what the issue might be?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
It's down to either the LCD or the backlight in this case since everything else appears to be working. Turn out all the lights in the room and hold a flashlight up against the screen and see if you can make out an image.
If so, then the backlight has failed. It could be either a board issue or a display problem; I'm not familiar enough with the iPad to be able to tell you where the backlight driver circuits are and if they're repairable or not, but hopefully some of our experienced Apple technicians will know.
Otherwise if it's the backlight itself or the LCD, either way you'll have to replace the display, which won't be cheap.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
redrott 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 9
总计 71
