跳转到主内容
Cardo Systems motorcycle bluetooth headsets: Packtalk, Smartpack, Packtalk Bold and Packtalk Black
Replacement USB connector P/N on PCB?
As with many other users I have a Packtalk Bold out of warranty with a bad USB connector. It works if the cable is held pressed up or down. Many have had solder failures but not this one, I need a new connector but studying images and footprints at Mouser and DigiKey has failed to ID a likely candidate.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
6条评论
Did anybody ever find a solution to this problem
完成的
The YouTube link shows someone doing it, not someone willing to share the P/N.
完成的
Meh. My question is, “what is the part number of the usb socket?” The YouTube video and poster refuses to share his secret.
完成的
显示更多的1条评论
添加一条评论
3个答案
已选择的解决方案
you can find the correct USB connector here....warning...its a bit tricky without the right equipment. I have successfully fixed two so far with USB replacements. If the trace has pulled away from the board....you may need to fix that also. https://www.amazon.com/gp/product/B00NQB...
这个答案有帮助吗?
得分 1
1条评论:
Thank you I bought a couple of these off Amazon from your link from uxcell and had my local “iKrack” micro solder shop replace one for me. It worked well.
完成的
添加一条评论
最有帮助的答案
is standard micro usb, but many Times on this model is the PCB lines missing, then need make jumper.
这个答案有帮助吗?
得分 2
添加一条评论
There is a good Youtube video on this process: https://www.youtube.com/watch?v=FLr-Keiv...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
David kelly 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 38
总计 1,409
