跳转到主内容
Guides and support for devices that play video from DVDs.
286 个问题 查看全部
Can't get RGB Component Output to work.
Hello, I recently bought 2 separate Sony DVD/CD Changers DVP-NC615 and I've run into the same problem with both. They will not output video when using component cables. Both work perfectly fine with composite or S-Video, but I get nothing with component. Not even sound. These are older players, so it's hard to find information about them. Not sure if I'm doing something wrong or if I was unlucky enough to buy 2 players with the same exact problem.
Update: after a lot of testing, I still can't narrow down the problem. I decided to focus on just one player. I've tested it on 3 TVs with various different component cables (as well as audio cables). First TV, intermittent connection. Second TV with same player and cables, got it to work. Third TV with same cables and setup, got it to work. Tried different set of cables, intermittent connection. Switched back to previous cables, intermittent connection. I have no clue what is happening here.
And yes, both sound and picture drop. I understand they are separate and I should still get audio without picture, but I don't. Can't get any consistency, ultimately.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @mattg10989
Have you checked that the Component video option works on the TV by trying a different device, apart from the two players that don't work using Component video?
Here's the user manual for the player.
Even if you didn't get the video, you still should get the audio from the player as it is the same connection as for Composite. See p.11 of the manual.
Here's the service manual that may also help.
这个答案有帮助吗?
得分 1
1条评论:
Hi @mattg10989,
Maybe check the video/audio ports on the dvd player for loose connections. If they're on a board (haven't looked at the manual) then maybe there's a problem with its connection
完成的
添加一条评论
添加你的答案
Matt G. 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 57
