跳转到主内容
型号 A1136 / 30, 60, 或 80 GB 硬盘 / 黑色或白色塑料面板
799 个问题 查看全部
The headphone jack isn't working properly
The headphone jack only allows the right earphone to work. I can jiggle the connector and it breaks up. How do I fix it? It doesn't matter if I change to different headphones... it still does the same thing.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
Check to see if you have broken a tip off any of your headsets. It may be in the iPod and preventing full contact.
这个答案有帮助吗?
得分 2
添加一条评论
This means that the headphone jack is becoming faulty and needs to be replaced. Simply locate the size of your iPod video and replace the headphone jack/hold switch. Very easy to do.
这个答案有帮助吗?
得分 0
1条评论:
What's the reason for the downvote? Sure, you should check the headphones out first. But this is a solid response.
完成的
添加一条评论
添加你的答案
SuzV 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 1,045
