跳转到主内容
The Dell Inspiron 15R 5520 laptop features a 14.88" screen, brushed aluminum finish and features a i5 core processor .
12 个问题 查看全部
شاشة الجهاز سوداء ويصدر اربع صفارات
عند تشغيل اللابتوب تضاء لوحة المفاتيح ولكن الشاشه سوداء ويصدر اربع صفارات
Google translate:
The screen of the device is black and it emits four beeps
When the laptop is turned on, the keyboard lights up, but the screen is black and four beeps are issued
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Hi @nbyllaamry
A 4 beep error code is a memory problem.
Try reseating the memory module(s) i.e. remove/reinsert the module(s) and check if that resolves the problem.
Here's the owner manual for the laptop. Go to p.19 to view the procedure to remove/replace the memory module(s).
If still no good, if the laptop has 2 memory modules try using only 1 at a time in case one module is faulty.
If it only has one memory module installed you will have to get another compatible memory module and try it. The laptop uses 1600MHz DDR3 SODIMM memory
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
نبيل العامري 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 7
总计 281
