跳转到主内容
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
1051 个问题 查看全部
iPhone SE power button completely not responding.
Hello, I've recently gotten to fixing my old iPhone SE, and I've gotten everything working except the power button. The ribbon cable itself is fine as it works on another motherboard, but only the power button just doesn't respond at all with the board I'm trying to fix. From what I've noticed, one of the small chips near the side button connector is missing, but I'm not sure if it's the culprit. Before I go out buying more parts, could someone confirm that the missing chip is in fact the issue?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I found schematics for your phone, but it's not clear from the signal labelling if the chip you're missing is indeed your culprit. The board layout shows it labelled as U0902, and the corresponding schematic says it's a 74LVC1G34GX.
Here's the schematic for that part.
The data sheet for that component says:
The 74LVC1G34 provides a low-power, low-voltage single buffer
74LVC1G34GX -40 °C to +125 °C X2SON5 plastic thermal enhanced extremely thin small outline package; no leads; 5 terminals; body 0.8 x 0.8 x 0.35 mm SOT1226
And of course the drawing for the connector itself would be useful.
Hopefully that'll give you a place to start; the other thing you can do is to run diode checks on the pins; that should give you a good idea of which signal is at fault.
Alisha (@flannelist), you're more familiar with Apple schematic nomenclature than I am; is the signal labelled "BUTTON_HOLD_KEY" related to the power button or not?
P.S., here's a picture of the are you're interested in taken from the iFixit teardown.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Creeper560 PL 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 12
总计 142
