跳转到主内容
A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
170 个问题 查看全部
Why is my PC power cycling?
My PC has been Power Cycling for the past week now and I'm not sure what has caused it. When I press the power button, it will start the process of turning on, the fans will start spinning and the RGB inside will light up, and then after around 10 seconds it'll shut down and then wait 2-3 seconds before starting the process over again. It was working previously and this randomly started without anything happening that indicated something was wrong prior to it starting. My PC's Specs in case needed:
RAM: 2x 4GB RAM
Motherboard: Gigabyte GA-Z87-D3HP
Power Supply: 700W FX Pro ATX PSU
CPU: Intel i7-4790S
GPU: ASUS NVIDIA GeForce GTX 1050 Ti
If anything else is needed from me just let me know and I'll answer as soon as I can. Thank you.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Something is telling your power supply to "reboot". The easiest way to determine what is causing this is to unplug things one at a time.
Turn your PC off and unplug it.
Then remove the power connections to everything except the motherboard. It should run through the POST examining everything on the motherboard and the video. You should see your BIOS splash screen.
If it continues to reboot, it is possible there is an erroneous setting in your BIOS.
If not, plug things in one at a time and reboot the PC. When it starts again, you have your "guilty" device.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
D.G 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 58
