跳转到主内容
Windows 10 是微软发布 Windows 操作系统的主要更新版本。该系统发布于2015年。
How to format a W10 os Hdd on different PC?
What I did was I took the drive out of the broken PC and tried to format it on a different one but it won't work. Is it because of some security thing?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
if you are using windows 10 at the bottom of the screen type diskpart into the search bar. open diskpart and type list disk and press enter. see which number the hdd you want to format is like disk 0 or disk 1. when you find the disk you want to format. type in select disk ( add number ) and press enter. then type clean and enter. after this go to disk management and format the disk
这个答案有帮助吗?
得分 3
1条评论:
Thank you so much!
完成的
添加一条评论
添加你的答案
NR26 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 176
