跳转到主内容
Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
545 个问题 查看全部
2011 MacBook Pro 17” works, but no internal display
I have a 2011 macbook pro 17” that boots, works, charges. External display works fine too, but no internal display. No water damage. Reseated lvds cable. Did pram, smc reset multiple times. Nothing worked. How do I debug? Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Let’s give this a try, take a flashlight aim it into the Apple logo in the lid, do you see a faint view of your desktop and its icon?
If you do you need to focus on the displays backlight logic, if you don’t the displays T-CON logic is likely damaged and/or the LVDS cable is damaged.
这个答案有帮助吗?
得分 1
3条评论:
Thanks Dan. I was not very clear. It’s not a backlight issue. I tried shining a light to the LCD, and there were no images. Also I tried using a different LCD, and same results, nothing on the LCD. External display still worked all ok.
完成的
@my980313e - then the logic board LVDS connector is bad.
完成的
Thanks Dan, I will give micro soldering a shot
完成的
添加一条评论
添加你的答案
my980313e 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 73
