跳转到主内容
A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
170 个问题 查看全部
Would using a higher rated power lead cause issues?
I'm not sure if I worded the title correctly but I don't know what else to call it specifically. The PSU I have is "rated" (I'm not sure that's the right term for it though) for 200-240V 6A. The only leads I have are either 250V 5A or 250V 10A. Would using either of these cause issues for my PC?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
In this case, you should use the 250V 10A power cord. You can go the same or up on voltage and amperage.
这个答案有帮助吗?
得分 2
添加一条评论
Hi @danielg60938
Might depend on where you are.
Using the 5A cable might not damage the PSU but may damage the cable or it becomes a fire hazard.
If the local mains power supply is 240V and the PSU is rated for 200-240 6A then a 5A cable is not sufficient. The cable will run hot if the full amount of current is required.
The maximum power that a 240 6A PSU can accept and use is 1440W whereas the 250V 5A cable maximum power rating is 1250W
The PSU may not require this amount but you don't know.
I would use the 10A cable to be safe. Let the fuse in the PSU protect it if necessary and don't use the 5A cable as a fuse.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Daniel G 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 41
