跳转到主内容
型号 A1136 / 30, 60, 或 80 GB 硬盘 / 黑色或白色塑料面板
797 个问题 查看全部
问题已关闭
harddrive to cf card change
Hi i see over here a realy cool thing about putting a cf card instead of a hdd it looks pritty easy and that shouldnt be a problem but i was wandering if i could subsitute a cf card (very expensive) and put instead a cf adapter with a sd card?
(i know the cf would work beter, but im just asking will it work? and how good will it work? (will it be totaly slow and bad?))
(while were at it would a sd adapter with microsd card work?)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hellow. mend.
I introduced a guide for cf card change, but a cd card and hdd are same ATA interface, so there are no problems.
In Japan, a cf card is not sp expensive.
32GB(200X speed) : $30-40(1$=80JPY)
I did not try your case, so I can not say it would work or not work.
I strongly recommend use cf card.
这个答案有帮助吗?
得分 1
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 1,014
