跳转到主内容
Gateway's NE51006u is a 15.6-inch laptop with a glossy silver plastic body. It features a quad-core 1.86 GHz Intel Celeron processor and runs on the Windows 8.1 64-bit operating system.
3 个问题 查看全部
when I switch on my laptop, it normallyboots , but suddely shuts down
when i switch on my laptop it boots up normally. it has a battery and shows fully charged. but when i switched off my power connection, it shuts down within a few minutes. Again i switched on my power connection and my laptop. it boots normally and works fine for sometime and again shutsdown abruptly. So i removed the battery and working with powwer adapter only. It is working fine almost from so many months except rarely shutting down when not kept idle for 15 minutes or longer. But suddenly from yesterday it booted normally, but shutdown immediately. It happened 4 or 5 times. So i opened the case and cleaned inside. but now it permanently not opening, no power light nothing. Any help is most appriciated
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Might be your laptop is experiencing a power-related issue. Check your laptop's power adapter. Remove the battery from the laptop and try powering it on with just the power adapter. If it boots up, the battery may be the issue and need to be replaced. Check your laptop's ventilation system. Overheating can cause the laptop to shut down abruptly. Make sure the ventilation system is clean and unobstructed. Sometimes incorrect BIOS settings can cause power-related issues. so, reset your laptop
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mandava Koteswara Rao 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 49
