How to change charging socket
This guide should come in handy: https://www.youtube.com/watch?v=8cnKvU91...
Make sure you order the daughter board that corresponds with your model, otherwise you may have service issues.
这个答案有帮助吗?
If i charge my fone it is not charging and i show to someone he replace it's motherboard and after few day it happen again
这个答案有帮助吗?
For changing a charging socket, start by switching off the power supply at the circuit breaker. Remove the socket cover by unscrewing it and then disconnect the wires with caution. Install the new socket by linking the wires to the correct terminals and then fasten it securely. Turn the power back on and check if it is functioning properly.
这个答案有帮助吗?
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 12
总计 626
