跳转到主内容
Why is my power adapter get over heated and problem facing while insta
Sir my adapter get overheated as well as while i was resetting my device and due to something my laptop get off and after that time i m facimg issue like windows cant in this device to install wi.dows restart the installation , sir i will be very thankful if u will provide me a solition
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
How old is the laptop and power supply and is the power supply (adapter) genuine? It's normal for an adapter to shut down if it gets too hot, likely from an internal repairable issue. See if you can swap it with another unit while installing. Many electronics shops will let you try theirs at no charge before you buy to ensure it really is the problem. Failing that, I'd be looking at the battery next.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Aaditya 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 52
