跳转到主内容
加入维修社区 - 创建账户
Originally known as Beats Studio Wireless, but often referred to as Beats Studio 2 Wireless. Released in 2013 along with the wired 2nd-generation Beats Studio as lighter, stronger, and more comfortable. Successors to the original Beats Studio.
Headphones won't charge nor turn on - battery already replaced
Hi all,
I bought used Headphones and fixed them myself. Now after 3 years of usage without problems, my beats began to act weird. Some weeks ago when I wanted to use them, they went out of power. Discharging itself while turned off. So I charged it and it works for some hours. Some days later again, empty without using them. Since last week no sign of life. I bought a new battery, replaced the old one, plugged the charging usb cable but no charge indicator. I tried the 2 min's reset button combo 3 times, but nothing happened.
I checked all power sources and cables. Everything else charges fine, but not my beats...
I checked all solderings and cables but they are fine too. Is maybe my motherboard dead?
I also checked the USB Port on the beats. No sign of damage, or wobbly cable. Cable sits nice and tight.
Usually a new battery is not completely empty. It should turn on right after plugging the battery, but nothing.. any idea?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Hi
It sounds like you have a bad main board unfortunately
If you really wanted you could try and fault find the bad component with a Multimetre to you could replace the main board
Here’s a guide for getting the board out
https://www.youtube.com/watch?v=NRnIeZqk...
If replacing this board doesn’t help it could be a issue with the Bluetooth board
Heres a guide for that too
https://www.youtube.com/watch?v=YSLjEneZ...
Hopefully this helps
Any questions please ask
这个答案有帮助吗?
得分 1
1条评论:
For me it was the Power Circuit board. Replaced it with a chinese ali express part. Now it works
完成的
添加一条评论
添加你的答案
Ifixstuff 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 14
总计 357
