跳转到主内容
How to check for continuity in power button?
As title says I want to check for continuity but am not sure how.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
What are you encountering now? A bit more info would help.
完成的
Power button doesn’t work, replaced trackpad fully thinking that was the issue it wasn’t.
完成的
添加一条评论
1个答案
The best way to isolate if the button is not working is to use the power pads Using MacBook Pro 2013 2014 2015 power pads if the system responds then the keyboard switch is damaged and you likely need a new keyboard assembly.
Here’s a deep dive into how the button works Macbook Pro Retina bad power button but every other key works!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
asdas sdasdsa 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 91
