跳转到主内容
Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
459 个问题 查看全部
Did I mess it up beyond fixing?
I took off the back of my 3DS to look at the insides tonight to check it out. I thought I was careful enough to not mess things up, but when I was closing it back up, I found this little metal piece on my mat.
Did I break something irreplaceable? Because that wasn't there before I opened the backside up.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
The beoken off piece looks like an antenna connector thar came off with a little bit of the circuit board. Unless you know microsoldering, I don't think you can repair it yourself.
这个答案有帮助吗?
得分 1
3条评论:
I still wonder how/if it'll affect powering on/game play. If it is wi-fi related, then hopefully it'll still work, as I don't have plans of trying to connect to another ds console. It doesn't have a charge right now since it had been years since it was last played and I'm waiting for a replacement charge cord. I did remove a considerable amount of lint from the charge port.
完成的
@alexciareynolds If it's just related to the Wi-Fi antenna, it might still work. I would try it and if it doesn't work, don't replace any components.
完成的
@andrewsawesome I got a charge cord and everything seems to work, including wi-fi, however it doesn't charge unless I jiggle and hold the charge cord at odd angles, which is its major problem to begin with. I think I'll take time from it before trying to fix it. I saw a guide somewhere that mentioned aluminum (foil?) tape and a heat gun to attempt having the port have a better connection.
完成的
添加一条评论
添加你的答案
Alexcia Reynolds 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 51
