跳转到主内容
Released in May 22nd 2020. It's has a 3,500 mAh capacity and bears the EB-BA415ABY identification number which falls in line with the A41's own SM-A415 model number.
11 个问题 查看全部
No mobile internet (3/4g) after replacing charging circuit board.
My A41 wasn't charging, so i replaced the circuit board with the charging port on it.
My mobile internet (4g) has very bad connection. however my wifi and bluetooth work just fine.
Also, people sometimes cannot hear me when i talk on the phone, but after recording my microphone seems to work just fine
Do i just have a crappy board?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Hi Jorik,
I would double-check the coax cable that runs down the side of the battery to the charging board. It's possible it either isn't connected completely or suffered damage in the process of replacing the charging board. Check the picture on Step 9 of this guide to replacing the charging board.
Charging connector Galaxy a51 repair - Free guide - SOSav
Check to be sure the connector isn't bent or broken and that the cable is also intact. Should you find anything wrong with it, it's replaceable by itself.
Galaxy A51 charging connector cable repair - Free guide - SOSav.fr
Good luck; let us know what you find.
这个答案有帮助吗?
得分 2
3条评论:
So the coax cable is responsible for Wifi, bluetooth and LTE?
完成的
@jorikjeeninga From the descriptions I read, it sounds like it. So it would be unusual for only one of those to be failing if it was a cable issue. That may tend to point to the replacement charging board being defective. Can you try swapping the old board back in to check?
完成的
unfortunately i discarded the original charging board. I replaced the coax cable and put in a 2nd replacement carging board. The problem persists.
完成的
添加一条评论
添加你的答案
Jorik Jeeninga 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 98
