跳转到主内容
了解您在设备上维修可能所需的技能。
87 个问题 查看全部
What is this connector, and how do I reconnect the cable?
I have been fixing some bent keys on my Roland rd88, and is now trying to reconnect this cable and connector:
It seems there are no latches to open.
I have this picture of another, similar connector type elsewhere on the keyboard pcb, but mounted flat:
Any help?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Hi
You see these sorts of connections on Roland products quite regularly and they are a push fit type
They can be quite stubborn to connect but the best way of slotting them in is by lining them up and pushing them into the slot by holding both sides of the cable in firmly
Try and keep the cable as square as you can to the slot to prevent damaging the cable
Hopefully this helps
Any questions please ask
这个答案有帮助吗?
得分 2
添加一条评论
It's a slide-in type connector. Slide that back in and check of the component is working. This cable should be inserted vertically.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
DonMeta 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 15
总计 57
