跳转到主内容
Apple 的第三代智能手表,配备可选的蜂窝网络功能,发布与2017年9月22日。
188 个问题 查看全部
What all parts is needed?
I see a few different parts listed for the 42mm series 3. my screen is falling off basically but i know it does still work. what all should be bought to do the screen replacement?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
screen is shattered. I forgot to put that up there.
完成的
添加一条评论
1个答案
最有帮助的答案
Hi Zach,
In theory, if your screen has indeed come loose, then the only thing you should need is the adhesive to glue it back on.
Apple Watch (42 mm Series 3) Adhesive Strip
However, it's been my experience that the screens generally don't just fall off for no reason. Most commonly it's because the battery has swollen and pushed the screen off the face of the watch. If that happens, then you need to add a replacement battery to your list of parts. I can't tell you exactly which one to get, as it appears there are differences between the cellular and GPS models of the series 3.
Anyway, you'll want to take a look at the battery itself; if it's at all pillowy or puffed up, that's a sure sign it needs to be replaced. A good, functional battery should have the outer layer wrapped tightly around it like a brick.
Apple Watch (42 mm Series 3) Adhesive Strip图片
产品
$6.99
这个答案有帮助吗?
得分 2
3条评论:
I forgot to mention that the screen is shattered but the watch still works.
完成的
@forsaken1 Ah, well that does change things. You can just buy the screen by itself, but then you'll need that adhesive I mentioned earlier as well. A better choice would be to purchase the Fix Kit which not only has all the tools needed, but includes the force touch gasket as well. The gasket frequently gets damaged when removing the screen so it's a good idea to have it on hand just in case, but it also serves as the adhesive to hold the screen on.
You'll still need to determine which one you need, the GPS or cellular version, as apparently the screens are different.
Apple Watch (42 mm Series 3 Cellular) Screen
Apple Watch (42 mm Series 3 GPS) Screen
完成的
@dadibrokeit awesome thank you
完成的
添加一条评论
添加你的答案
Zach 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 28
