跳转到主内容
TI-84 Plus calculator support.
Arrow Keys don't scroll through previous calculations
The "normal" behavior of the arrow keys is to scroll up and down through previous questions and answers, but my calculator's ones act like the "home" and "end" keys. I've tried multiple factory/default resets and it still doesn't change.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Press mode and check that you're in Mathprint mode not Classic mode. An OS update to OS 2.55mp might be needed.
You can repeatedly press 2nd then enter to cycle through calculation entries.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
Hi
Has the calculator had a battery leak at any point in its life?
If so that may be the cause of the issue
It could also be caused by debris inside the calculator
Here’s a disassembly guide
TI-84 Plus
If you corrosion is found I would recommend cleaning with isopropyl alcohol:-)
Hopefully this helps
Any questions please ask
这个答案有帮助吗?
得分 1
2条评论:
Never had anything related to a battery leak. It just happened today morning, I was doing math work fine yesterday and it scrolled up and down just fine. The up and down arrow keys actually work, but the problem is their intended function (scrolling up and down) have been replaced by the "home" and "end" behavior.
完成的
@moony19142
That’s wierd
It might be worth reinstalling the software along side some other things
Here’s a link to doing that
TI-84 Plus CE Recovery Techniques.
完成的
添加一条评论
添加你的答案
moony 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 28
过去 30 天: 100
总计 2,760
