跳转到主内容
Model A2159, EMC 3301. A refresh of the entry-level 13" MacBook Pro. Available in Silver and Space Gray. Released July 2019.
112 个问题 查看全部
How to remove stripped p2 pentalobe screw on antenna radio bar?
Was tried to replace the screen on my MacBook Pro a2159 2019 model. While removing p2 pentalobe screws on WiFi antenna radio bar, came across a screw that was already stripped. I am stuck there and can’t remove it. What would work? Also can I buy a replacement p2 pentalobe screw?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
It sounds like you’ll need to drill out the remaining screw. If the head is still present try heating it up with a soldering iron, then try turning it while hot. Apple used a thread seal that softens with heat, otherwise you can get the Loctite solvent Loctite SF768
Here’s the screws Antenna Screws
这个答案有帮助吗?
得分 1
3条评论:
Any recommendations for which drill tool/bit will work for p2 pentalobe screw. For trying soldering iron, any recommendations on the tool?
完成的
@rrp48565 - As the diameter of the screw is only 2mm you wouldn’t want more than 1.5mm so you don’t loose the case side threads. You would also want a left hand drive bit so the direction of force is with the direction of the screws removal.
A 35Watt pencil iron should be enough. I would really give that a try first.
完成的
Have you tried using a small flathead screwdriver? When i strip a screw, that is always my go-to,
完成的
添加一条评论
添加你的答案
RR P 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 32
总计 352
