跳转到主内容
How can I install a wifi adapter?
How can I install a wifi adapter for my HP 256 G4
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
Hi @esakesak
Have you checked the status of the WLAN network adapter in Device Manager > Network Adapters i.e. not installed correctly (yellow exclamation mark), disabled (red cross) or not listed at all?
If there's no appearance in Device Manager, check if the WLAN adapter has been enabled in BIOS.
If there's no WLAN enable/disable setting in BIOS check if the WLAN module is missing from the laptop.
Here's the maintenance and service guide for the laptop. Go to p.44 to view the procedure to remove/replace the WLAN module.
If there's none there or if perhaps it is faulty at the top of the page you'll find the model numbers of the 3 WLAN adapters compatible with the laptop. Two have Bluetooth capability as well as WiFi and one doesn't so be aware of that if you need a replacement. Search online using the part number only to find suppliers that suit you best.
这个答案有帮助吗?
得分 1
添加一条评论
Typically wifi adapter drivers are installed automatically depending on your operating system. Many WiFi adapters can be installed through the USB ports on your laptop, like these.
这个答案有帮助吗?
得分 0
添加一条评论
Well you can try the following:
  1. Download the updated driver and extract it.
  2. Right click on Computer Icon, and then click Manage.
  3. Open Device Manager.
  4. Click Browse my computer for driver software
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Esakesak 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 113
