跳转到主内容
加入维修社区 - 创建账户
AirPort Time Capsule 是由 Apple 制造的无线路由器和网络附属存储 (NAS) 设备。A1409 型号是 2011 年 6 月发布的第四代 Time Capsule 改版。
Replace airport card/modem in TC gen 4 (802.11N)
Can I replace the Airport Card/Module in the Airport Time Capsule A1409 4th gen (802.11N)?
I fear the answer is Duh, NO!, but the answer is always no if you don't ask.
Thanks, Mark
PS: Is it worth replacing the HD with a SSD?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
While you can’t alter the capsules WiFi interface, you can still connect a WiFI unit externally! As far as swapping out the HDD to a SSD while that can be done, you won’t get the best performance as this units SATA interface is only SATA II not SATA III
So consider your needs, review your cost Vs benefits.
这个答案有帮助吗?
得分 0
1条评论:
Thank you. Cost is a biggie, but having pieces parts lying around, had to ask those with more experience, skills and knowledge than me.
It works well, as a basic backup, but occasionally I get the Tim "The Toolman" Taylor moments, and want to make it faster, better just because it's (sometimes) possible. ; )
完成的
添加一条评论
添加你的答案
mark ray 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 362
